Project White PH1!
Cheers mate
Got some more bits removed including the crappy tarmac laid on the floor lol.
Had a slight chance of plan on the colour scheme but the main colour is still white!
New crossmember and other bits arrived today but going to finish ditching the a/c and fit the new subframe before welding this on.
Thinking of the multipoint weld in OMP cage unless anyone has a better suggestion?
Bilstein coilovers i think....
Brakes, hmmm unknown for now but i'm going to kiss the ABS goodbye and add a manual bias setup.
Paul
is white a colour from the manufacturer?or been sprayed ? id love a white car but very impractical.
you should look at that paint that doesnt let mud or dirt stick its sort of a selfcleaning paint as far as i now its only for industrial use but is applyable to a car
for brakes paul just go for carbon lorraines and brembo max's with ss lines and 5.0 fluid you really cant beat them they just keep braking and braking
meaning - you think your breaking quickly to find it will actually brake even more!
and dont fill up all your time mark will be back to have his worked on again and mine will be getting brought down once my cage and stuff is in :)
^shut up about your gayboy, shitty carbone lorraines, they ain't s**t compared to blues or PF's, they're the poor man's "track wannabe" pad
if they were so fantastic then the cup racers would've used them, they didn't, mr ragnotti said that PF's were the daddys, and then mr ragnotti decided on endless for the new racer
even the grpN cars don't use them!
Managed to get a cage from one of the cup racers so got that in today ready to mark up for the plates and get the holes drilled :)
OMG how tight are these to get in!
Only downside is that they are for left hand drive so might have to swap the section from one side to the other.
Will be starting on the bodywork asap so should start coming together soon
Paul
^shut up about your gayboy, s**tty carbone lorraines, they ain't s**t compared to blues or PF's, they're the poor man's "track wannabe" pad
Brembo Max's, Stainless Hoses, Pagid Blue's, RBF600 fluid, and Cup Racer Brake ducts work very well for me! ;)
Aiming to have the whole outer shell prepped for paint this week :)
Just need to find a back axle as it appears mine is bent!
Just like the front subframe :(
Nice find mate, i should search better on egay!
I actually won a subframe on ebay but the seller decided to tell me someone stole it! PMSL! Ok i beleive you
Sorry no recent pics but got plenty done in the last week or so
The inside is totally stripped, all brackets, clips sound deadening and other useless parts have been drilled out!
The spreader plates are welded in for the cup racer cage
i cut the rear seat brackets off from the strut tops so judt need to weld and seal that!
This week the plan is to get the inside prepped for paint, mock fit the cage (again!!!) to drill the holes, that can then go back to the powder coaters.
I'll get some pics up asap :)
if you won that beam on ebay and you just wanted the axle, assuming the hubs are ok fancy selling me the brake setups off it?
or even just the bent axle complete?
cheers
cheers
Yeah not a problem :)
Make me an offer, or come swap it over and you can have it!
couple of saturdays time convenient? (working next saturday so saturday after?)
will give you something for it obviously let me know mate.. dont mind swapping it over for ya.
thanks.
Yeah should be no prob, but it will have to be on axle stands as my ramp is still laid on its side lol
tomorrow i should have a new seat (other is on back order from france)
Here's what they look like - the harness (not road legal!)
197 cup racer seats :D
