Who to use for this engine work?
Failing that, I'd go with whoever Fred is/works for. I haven;t met him, But he seems honest, Knowledgeable and seems a sound guy.
Me too, he'll get you 13bhp from a Viper induction kit and I hear with a remap and an exhaust you'll be knocking on the door for 300bhp ;) hehe
Fred is sound, he does come out with some absolute gems though :)
Ali
  V6, Trackhawk, GTS
Martin,
Don't attempt the belts yourself! Unless you know what your doing...iirc your not a mechanic...?! No sure, but i'd pay for that work! Cams...The gains are minimal, like i say every time you bearly notice 25bhp! mine only just pulled away from a std 172 so that puts 2k or so into perspective!
Listen to jon ^ a Viper will get you 13bhp! ;)
Martin,
Yup i agree, when i had a play with a standard 172 it was quicker but wouldnt exactly power past, get that 2k pumped into somthing jap....FTW!
cams are worth it, note the people knocking them dont have them. it's a good gain for the outlay, but I'd spend the money on an Omex instead
Martin_172
na dont really want to go with aftermarket management, just thought cams would be worth while since the cambelt was getting done anyway but dont want to go spending mega money.
Ali
  V6, Trackhawk, GTS
Cams are Not worth it, you'll get approx 6Bhp is your lucky! - Were you not involved in that conversation with Kevin @ Falkland!?
Tom
  i3
Thats better, keep on topic please.
That also includes you Ben you gigantic dong. ;)
I said that's what "I WOULD DO", but then I wouldn't stop at just cams personally.
Anyway, your getting the belt done, it makes sense to uprate the cams for some easy power that's not going to cost you much or anymore in labour. Cost effective mod given your belt needs.
Wouldn't worry what some dude said about cams only giving 6bhp, that falls under "not knowing ones arse from ones elbow". If everyone else had reaslised this too, then cam retailers would go out of business when you can get those gains from a couple of easy breathing mods
Tom
  i3
Sounds a bit low, but then if you dont map to take advantage of the cams properly...
true, but even without mapping I'd expect more than that... not sure about F4R's in regards to cams without suitable maps, but on the F7R's just cams on their own give a notable and obvious power increase that's hard not to spot.
Ali
  V6, Trackhawk, GTS
Boy up here got a set fitted to GDi's spec...No names mentioned and gained 6bhp! Pathetic! And that set him bak over 1k! not bad a little over 150£ per BHP! :rolleyes:
Martin - Basically the message was don't bother.
John nout to do with cam companies going out of business, but rather more emphasis on cams being a part of a package, not just on it's own.
M
mini-valver
Lol^^
Cams WILL give you a noticeable increase in power! If you're having the belt done, £500 on a set of CAT's isn't a massive outlay. Add your inlets (exchange basis), exhaust and decat then shoot down to RStuning and have it mapped. You could do it all for 1.5k I reckon. A belt change is £500 odd so 1k for about 15-20 bhp is good going....
  Ph1
Something must have been seriously wrong then. :S
Iv got roughly 25 bhp over standard with 'shitty' Pipers among other things and standard 172's / 182's are not even worth breaking a sweat against the difference is that big.
Ali
  V6, Trackhawk, GTS
Iv got roughly 25 bhp over standard with 's**tty' Pipers among other things and standard 172's / 182's are not even worth breaking a sweat against the difference is that big.
I'm dubious of that!!! Would want to see it to beleive it!
Never seen cams on there own make more than 10brake!
Couple with inlets, maxogen, remap and zorst your lookin at the 200brake mark!
If you got 25brake from cams alone, with the rest of the work your lookin at TB power....That i doubt!
All the mods I have had done on my car:-
182 manifold and cat
omex and idle control
maxogen
cat back prospeed
On the rolloers back to back with a standard 182 mine made 20 bhp more than the 182 and mine hasn't got sports cams....
  Ph1
Not the cams on their own no, coupled with the other mods iv got but the cams were where the big difference came from
25bhp over stock and it should pull like a train and well over a standard 172 / 182 from experience
Ali
  V6, Trackhawk, GTS
Maybe your definition of pull like a train is different to mine!
Mine was fast! 171 as std and 192.6 after all mods, so 20ish brake up on std! I could catch and pass, but not even to go! WOW!
  M3 Touring
hahahaa i love these threads!
If you truely want to make your 1*2 "alot faster" "pull like a train" "rapid" etc etc.. your gonna have to spend atleast £5K + on engine work alone
  ITB'd Ph1 172
unless you have driven these cars, none of you can really comment...
i am sure the owners would be more than happy to demo either way.
Ali
  V6, Trackhawk, GTS
Seen, driven, broke!
RS tuning is a mug's game, made even worse with wild mods.
Buy a faster car it's the only safe sensible option!
  A well built VW
Martin , save the money and put it towards your Jap car fund and concentrate on enjoying the car as it was meant to be
IMHO its just a waste of money I spent many years spunking loads of cash at mods and regret it now - could have bought a really nice car with the money wasted on mods alone lol
