how to stop wheelspin?
Car  1.8 valver,williams,105e
Hi,had my 1st trackday in my williams trackcar,its got pipercams fully stripped etc-its a proper rally/trackcar it runs slicks and de-carbon front legs and gaz rear adj shocks
basically when coming out of the 2 hairpins at rockingham im getting excessive wheelspin(one wheel)even in 3rd it was smoking the tyre in fact i fucked the diff by diner time ,i no lsd is the way but has anyone got any other advice to prevent sum of it at least? i no the basics like tyre pressures,feathering the throttle etc
your thoughts please....:dapprove:
thanks
LSD is the only way really.
apart from that you can only try to stiffen the chassis and prevent body roll
just sold my rs turbo cos of g/box snapping probs might get a bmx instead!
the gripper diffs are 820 quid tho...ouch!
Your problem is unloading the inside wheel and an open diff.
Your problem is worse than normal as slicks generate higher G loadings and affect weight shift more. You actually lighten the inside wheel more, and eventhough it is a slick you have less grip on that wheel and it spins up.
LSD is the answer....or go in faster and slide the bugger.
Did think about welding it up but trying to turn in will be a night mare!
cheers for your advice poeple
