Track rod ends
  PH2 172
Hi,
I picked up my new motor today (PH2 172) and noticed the tracking was slightly out. Popped into a tyre place and they tried to adjust it but the bolt was stuck onto the track rod end, and they couldn't free it up.
The guy said I may need to replace the track rod ends, in order to free it. Anyone know how much the parts are?
i don't know for sure but would guess that they're less than a tenner for a pattern part (GSF etc). it's not unusual to have them seize - you may need to use an oxy torch to get them off although perseverance and Plusgas/WD40 might do
  PH2 172
Aye - they had a go with the oxy torch but it wasn't shifting and they didn't want to break it :p
I've got some plusgas, I'll give it a few sprays see if it helps
  www.renparts.co.uk
Problem is if they apply too much force/use to long a bar it can pop the ball from the end joint, not sure if a pattern one is available but worth checking.
Alastair.
  986'S 172ph1+182FF
spay the down in duck oil, leave over night and they should come free, the garage wants to try heating them up, wel thats how i free em up:)
