Track rod ends
Car  PH2 172
Hi,
I picked up my new motor today (PH2 172) and noticed the tracking was slightly out. Popped into a tyre place and they tried to adjust it but the bolt was stuck onto the track rod end, and they couldn't free it up.
The guy said I may need to replace the track rod ends, in order to free it. Anyone know how much the parts are?
i don't know for sure but would guess that they're less than a tenner for a pattern part (GSF etc). it's not unusual to have them seize - you may need to use an oxy torch to get them off although perseverance and Plusgas/WD40 might do
Aye - they had a go with the oxy torch but it wasn't shifting and they didn't want to break it :p
I've got some plusgas, I'll give it a few sprays see if it helps
Problem is if they apply too much force/use to long a bar it can pop the ball from the end joint, not sure if a pattern one is available but worth checking.
spay the down in duck oil, leave over night and they should come free, the garage wants to try heating them up, wel thats how i free em up:)
