Clio 172 VVT Type
  Clio 172 Sport Ph2
Can anyone tell me what type of VVT system the 172 runs please?
Is it a simple on/off at a set rev point or is it a more complicated version like other systems.
I need to know so that I can make sure the new ECU I'm lookin at will cope with it.
Lee
Dont know if its any help but I believe it activates when the coolant reaches 75c. Hence them running like crap from cold for a few mins.
  VaVa
Do a search. It's been posted many times. And that's wrong i think ^^^ It's a simple on/off cam phasing type. Between 1400 rpm and 6500 rpm iirc.
They run like s**t when cold because of stringent emission control - They run as lean as possible when cold, hence why they're stuttery for a few minutes.
Posted by Henk
VVT explained
Here is some additional info about the camshaft phase shift system as used on the Clio RS. (2000-2005)
The VVT system is only active after certain conditions are met, like coolant temperature / battery voltage etc.
Once these conditions are met , the ECU looks up engine load and rpm in a 3D table and activates/deactivates the cam shifter accordingly.
For the 182 that means VVT is active from 1450 to 6850 rpm and from light/moderate load to full load.
The 172 shifts back 150 rpm earlier. All settings can be changed as required.
As most of you know the VVT is a 2-step ON/OFF system. However the ECU is capable of sending a PWM signal which turns the solenoid on/off in 6 steps. From 25 - 100 % duty. Renault does for some reason, NOT implement this feature on the 2000-2005 models.
  Lionel Richie
really? hum, have i confused the cam sensor for a vvt solenoid or something stuipd?
i was 99% sure it was vvt on both cams?
  Clio 220 lpg
had a bit of time to see whats different tonight and all there is are diff springs, inlet and exhaust cams on the head which suprised me:eek:
Tom
  i3
Nope, F4R 830
Induction Capacity (cc) 1998
Bore x Stroke 82.7 x 93
No of Cylinders/Valves 4 in line / 16
Compression Ratio 11.5 : 1
Maximum Power - kw ISO (hp DIN) 145 (197) to 7250
Maximum torque - Nm ISO (mkg DIN) 215 at 5550
Injection Type Multipoint Injection
Fuel Type Unleaded Petrol
Catalytic Converter Standard
M
mini-valver
Yeah, just has a bigger bellhousing for the box but the code's still the same.
Says the man who clearly contributes alot to this website who has 95 posts LOL
At least I try my best to help people where I can (I was wrong on this occasion). Like I said dont know jack about the 197 engine but know a fair bit about the older ones
  Renaultsport Clio 172
Does anybody know if the VVT from the intake can be implemented in the exhaust, just wondering this could give a better performance. Would this be feasible?
Not without redesigning the camshaft to be of a hollow oil pressure carrying design and installing a complex dual constant vvt management.
Feasible, but highly pointless.
  172 phase 1
Posted by Henk
VVT explained
Hi am running my 172 on 197 cams with a 8 degree advance and with a trumpet length of 27 whats best vvt activation range to be running then with this diffrent but fairly common modded cam setup on a standalone thats set currently for running simple on/off variation range? 1450 to ...... ???
