Don't think so, it's def f4r engineNopey completely different engine, box the works...
197 has vvt on both inlet and exhaust cams, 172/182 is just on the inlet
Fair enough didnt know that! To be fair I know diddly squat about them but was under the impression from what I'v heard its a completely different setup.
though he answered anyway ?? typical of this forum which is why its crap :quiet: theres probably less than 5 people on here i would actually listen to!!
you are correct Henk, oops, serves me right for not reading all the info! lol![]()
hollow oil pressure carrying design and installing a complex dual constant vvt management.
try and say that pissed!
Posted by Henk
VVT explained
Here is some additional info about the camshaft phase shift system as used on the Clio RS. (2000-2005)
The VVT system is only active after certain conditions are met, like coolant temperature / battery voltage etc.
Once these conditions are met , the ECU looks up engine load and rpm in a 3D table and activates/deactivates the cam shifter accordingly.
For the 182 that means VVT is active from 1450 to 6850 rpm and from light/moderate load to full load.
The 172 shifts back 150 rpm earlier. All settings can be changed as required.
As most of you know the VVT is a 2-step ON/OFF system. However the ECU is capable of sending a PWM signal which turns the solenoid on/off in 6 steps. From 25 - 100 % duty. Renault does for some reason, NOT implement this feature on the 2000-2005 models.
