removing engine bits???????????
Nafoff
wanting to remove the plenium (sp) and the fuel rail guard for painting.
1) is this easy enough?
2) is there anything i need before refitting? ie. gaskets etc.
cheers neil
i am sure it will be obvious when i go to do it but can you describe were all the bolts will be just incase there is any hidden ones i miss.
will look into the plenum gasket.
just go steady with the ratchet when your doing them up as the upper plenum ones are easy to strip the threads.
Watch the clips and sensors...bein french these can be troublesome in the future.
iv had my inlet off loads and still on original gaskets matey,though im investing in a new set of inlet bolts as mine are starting to get a lil old
