Panel filters - Do they actually make ANY difference?
i have an ITG and the only difference i would say was in mpg, but then again my standard filter wasnt the best ever.
if you apply a little thought, you can satisfy your curiosity by removing parts of the OE system to see what difference their absence makes.
that said, the fuelling/timing will need setting to suit to see maximum benefit.
Maxogen is a shocker at £400 IMO.
Perfomance on track tells another story.
As do RR figures.
Makes a big difference high up the rev range.
So no it's not all in my head & some of us don't worry about the cost.
Thought everyone on CS was on £30K+!!! ;)
Ive just bitten the bullet and got an ITG one, and yeah i reckon its made a difference. Coming back from Manchester airport uphill on the M62 in 5th @70ish, put my foot down and it just wanted to go! Only downside ive noticed is my wheels now bounce more than ever on accelaration!
I have a Maxogen & yes there is a difference.
I hear that the Maxogen does give positive results, but I was just asking about panel filters. :)
Seems that the one to go for, if any, is an ITG then.
I take it that these are like the K&N and NEVER need to be replaced...
a clean paper one will flow just as good as an aftermarket one in reality. its much tighter yes but the increased surface are compensates for that.
a clean paper one will flow just as good as an aftermarket one in reality. its much tighter yes but the increased surface area compensates for that.
I dont think it makes a difference on its own but helps when you have other mods. Ive got an ITG.
Had this chat at college n we came ti the conclusion that (obviously) cars just can't be modded the way they used to be. In an older car yes it may well make a noticable difference but engines are so advance not a little air filter wont change much if anything.
Best thing to do is change the cams for some high lift, longer duration cams, a re-map and then the filter could make some difference.
Red standard, blue Viper and GDi exhaust
You don't always need a remap to get a response out of basic mods :p
no lol wast of money imo.
all in ya head dude ..lol only diff is that they cost more ....
Waste of money? Cost more?
An ITG panel filter costs £47 once, and it lasts forever...or you could pay £15 for a paper one at every service.
You do the maths.
I've done probably 85k on mine now, and all it gets is a blast from Mike's air-hose at every service (6k).
As far as any difference goes...can't say I've ever noticed any - apart from the cheaper servicing.
Actually, you'll still be charged for the filter at a service; they'll charge for washing it. And if you take it to Renault for a service (which is the worst thing a sane person can do) then they probably won't even clean it - and still charge the £15ish for it!!
:lolup: Renault will not charge u £15 and of course they dont bloody clean it!
how is this thread 2 pages long ????? NO panel filters dont make any difference what so ever, it will just save money over x number of years
Not sure if this has been posted before, but this test shows that foam filters perform badly in filtering efficiency, while "wet/oiled" cotton was a little better.
http://mkiv.com/techarticles/filters_test/2/
In the test below, it showed that a clean paper filter is in fact the least restrictive.
http://www.bolhuijo.com/airflowtest/
With this in mind I intend to stick to the standard oem or a good quality paper filter and change it regularly to have the best performance and protection.
my car made 175ps (173bhp) on the rollers, at a RR day where the results were VERY accurate and consistent.
obviously different cars /engines are different, and make different power but when most 182's and 172s were making just under book power, mine making over seemed to be good!
^ interesting read
