Exterior
172 cup spoiler, brake light
Psh2 172 rear bumper
Psh2 rear lights
psh2 side strips
carbon fibre roof
carbon fibre bonnet
6000k HID kit
CC handels
K-tech carbon fibre splitter
manual mirror conversion
clear side repeaters
cup racer front tow eye
cup racer rear tow eye
sparco alloy boot pins
areo-tech flush lockable bonnet pins
single wiper conversion
Brakes
Comp pro race 3 callipers with CNC alloy brackets
HAWK fast road pads
stainless braided front lines
alloy bells
iron povervain 295mm goved rotors
2lb residual lines
mocal rear stainless braided lines
QH groved rear disks
Mintex extreem rear pads
drive master bearings front and rear
ATE super blue fluid
suspension
Leda damping and hieght adjustable coilover bodies
eibach race coils
whiteline rear camber shims
compbrake alloy solid top mounts
Powerflex wish bone bushes
182 25mm front ARB
182 rear beam
powerflex ARB bushes
leda camber bolts
wheels & tyres
Speedline 2118s 15" x 7"
Speedline **** 15" x 7"
Dunlop Slicks
Mitchlen PE2s
Stud conversion
Interior
Cobra Evoution S (renault sport emriodery)
Cobra Evoultion S GT width (renault sport emriodery)
Sabelt superlight 6 point 3" race harness x 2
Eye bolts
custom 5mm subframes
alloy 5mm sidemounts
carbon fibre doorcards
carbon fibre handles
custom made fibreglass dash (flocked)
multipoint weld in OMP cage (painted)
Interior stripped and painted
Alloy redtop battery box
OMP superquadro wheel
OMP boss
Megan 225 footrest
manual window conversion
STACK oil temp guage
STACK oil pressure gauge
STACK boost guage
STACK fuel pressure gauge
STACK AFR guage
Alpine CD player
2x sony 13cm speakers
kill switch
starter button
fuel pump key switch
alloy floor plates
Flame beater extingishers
psh2 handbrake button
Engine
knife edged and race balence crank
uprated engine shells and bearings
forged rods
alloy flywheel
low comp pistons (over sized)
extensive headwork and valve work
Alloy custom made inlet manifold
carbon fibre plenham
alloy TB
ARP rod bolts
ARP flywheel bolts
Remote oil filter
custom SC bracket
rotrex 30-94 supercharger
760cc siemans injectors
water/ethonol injection kit (fully mappable) with HSV
WET 75hp N20 kit (progressive controller)
CAT cams
Stainless steel valves
standalone management
custom race loom
de cat
exhaust
intercooler and custom pipe work
engine oil cooler
group n engine mounts
custom ally rad
supercharger oil cooler
heat wrapped manifold
green cotton filter for charger
mocal oil catch tank
100 psi race fuel pump
100psi FPR with local guage
braided incar fuel lines
custom fuel rail
pro alloy swirl pot
2 x redtop low pressure lifter pumps
uprarted oil pump
uprated HT leads
Uprated sparks
3 bar map sensor
custom samco water hoses
custom oil lines
transmisson
Avanti gear set and rods
avanti LSD bolt on crown wheel
interchangeable final drives
custom drive shafts
Al-con paddel clutch plate
helix pressure plate
AP bearing
mocal remote oil pump
mocal filter
mocal oil cooler
mocal fittings
ive missed loads off , but you get the idea
