ferodo DS2500 problem
Barron
  Turbo S,Exige,R5,182
hey, fitted some ferodo DS2500 to the 172 500 miles ago. They were a tight fit so had to take a mm or 2 away from the wings. They fit perferct and have lots of meat on the pads but i have found a problem.
After heavy usage the pads are sticking and making it squeal, after a run out and quickly jacked the car up and tryed turning the wheel. The wheel was very stiff to spin but became easy again once the pads had cooled down.
Is this just the pads expanding and due to them having alot of meat left as they are new sticking to the disc due to lack of space inbetween pad and disc?
/carl
Barron
down the sides as they were too wide for the caliper, took it equally off each side. The wing bits
/carl
  S1RST/205GTI
Mine were like that at the start and are ok now,dont know if they were still like that after 500 mile though.
Barron
dress the edges down a bit more, you taken the wee shims out of the calipers?
left the shims in and just copper slipped them. should they be ok straight away like Fred?
/carl
  Clio 172 ff
The Ferodos are supposed to go on there without the shims. Maybe that's the reason for your problem?
Strange that so many people seem to have to grind them. Mine fit just fine right out of the box...
Barron
hmm well i cant see the problem with keeping the shims in after they have've had a little bit taken off them
/carl
yeah shims should have been removed, you might need to get a new set now you have taken bits off those depending on how they fit after u remove the shims
Barron
well how loose should they be? as they are tight with the shims in
/carl
