Quick photoshop measurment question
Car  E39 530i
Im designing a fyler in photoshop, I want the original size when printed to be;
Width = 12.5cm
Height = 20 cm
Do I set the canvas to be the settings above or large?
Set the canvas to this size unless you want a bleed (in which case at X mm around the edge and have the image overlap where you want it cut).
To change the quality you want to higher the DPI (dots per inch) from 72 to 300 which will make the canvas seem 5x bigger, but it's the same size and everything will be squished (as such) into the size you want to increase quality.
Hope that explains it.. :s
Not really, lol. whats a bleed?
Bleed is the extra work (usually 3mm) added over the edge of a page so that when something is cut or trimmed, you won't get any white paper if the cut if slightly off.
For example, if your flyer has a 'finished' size of 12.5 x 20cm (125 x 200mm) then you would need to create a document 13.1 x 20.6cm (131 x 206mm). That slightly larger size will include the bleed - and whoever prints it for you will love you that little bit more. :)
...and as Matt said, do it at 300dpi (12dpm)
Set the flyer up at 600dpi not 300dpi if text is involved - you get a much crisper text :)
If it is being professionally litho printed, then raster images will (usually) get down-sampled to around 300dpi anyways :)
If you are using text, then it is best to use a graphics package (eg: Illustrator) or a page layout application (eg: InDesign). This will keep text as vectors and output will be sharp.
Thats what separates good and bad printers :) I'll never downsample a photoshop job if it has text in it - any modern day RIP will find this a breeze and running it 200lpi you'll see the best quality.
heh. Fair point! :P
Do people actually bother printing flyers at 200 screen though?
heh. Fair point! :P
If its on coated stock then yeah we default at running it at 200lpi - the press guys have no problems holding it - if uncoated then yeah we turn the dot down to 150lpi.
