renault offer two bodykits for the mk3 clio
they can go buy serval diffrent names
first its the soft kit / universal / classic bodykit (fitted standed on the dynamique sx)
this kits is 910quid on a new build clio this includes all skirts an spoiler fitted an painted on a brand new car
you should be able to buy these parts seprately from renault
contains all the part numbers you need last time i checked they were around 100pounds each
better pics
the universal as far as im aware fits all clios regardless of wheel size
as far as i know ive seen it on 3drs dynamique s which has the wider wings an 16inch cansta alloys ( the sx added the kit from the factory)
ive also see this on a 5dr clio ripcurl with the 15inch mahonia wheels
the sports kit
the sports racing kit looks much more agressive an is 975 on a new build again all parts painted fitted
if you require the parts as you can see it requires parts depending on your car
the sports kit will only fit the models with 15inch wheels cause these models have smaller wings basicly which will be the clio rip curl the dynamique extreme as its a more dramatic fit as you can see below
the problem with this kit it will not fit most 2008 onwards due to model changes it may fit the rip curl an expression but will not fit the dynamique or s as the both have 16inch wheels a wider wings as standed
hopefuly this will help
as ive posted it alot an it gets missed
better pics
the sports kit
