Where to get a 1/8"NPT Oil pressure sender ?
bump
heres my setup:
and from cold:
Looks great mate.
Bet you was glad that the engine was out to do it ?
So much more space :)
My oil gauges are disconnected the now and my standard oil pressure switch is back in its place as my oil pressure sender has started leaking oil where it screws into the t piece :(
And i'm gonna try and reduce the amount of fittings i have attached to the senders ;)
So its work in progress again :)
Where did you get your t piece and fittings Matt ?
As i aint to fussed about loosing my oil temp gauge if need be to reduce clutter a bit ;)
Was it Pirtek ?
And did you have to order any of the fittings ?
Or were they all off the shelf ?
was pirtek, Justin (building the 2.0 mk1 turbo) bought them for me :)
was off the shelf iirc
