Exhaust Mount
Car  Clio 200
Exhaust was sitting squint so took it back to the garage who fitted it and it turns out the rubber bits on the exhaust mount has perished.
anyone any idea much renault will over price them at?
cheers
Got my exhaust mount from renault for £22 then to make it more stronger cut 3 pieces of copper piping and put 3 pieces of coolant hose over the each piece of copper pipe then put 1 pices at the bottom of the mount in the gap and the other 2 pieces in the top corners ill get a picture and show you your exhaust will never hang low again.
That it once finished
Wot he said ^
Because it just makes it that more sturdierand more stronger and with the coolant hose it sits in there really nice so wouldnt move about i think if u didnt use the coolant hose it would move about etc
What mm piping was it btw? And why bother with the coolant covering?
Because if your using metal piping it will cut and wear through the rubber of the clamp in no time
Plumbers copper piping just about does it all be it a very tight fit. The thinner stuff not regular size
That is copper piping from a plumber which i have used 1/2 inch copper piping but woth the coolant hose it just absorbs the movement and also liek said stops it from wearing the rubber
