sick of my caf
Car  Astra van,Mk1 nova
looks mink now imo
just bought a new lower grill!
so going to relocate it to the foglight as i never ever use them, even when its foggy :eek:
but only problem is the trumpet i have at the mo is to big for the foglight, has anyone else overcome this problem, please share ;)
does it work ant better there mate or are you moving it because you dont like the look of it, i thinks it looks cool as it is??
sick of the look of it tbh, i like the look of it in the foglight. also straighter run to the cda if its in the foglight any thoughts?
You can buy smaller trumpets, can't remember the site, however
I have mine in the same place as yours, and I like it :p
If you want to convert the foglights, make them into brake cooling ducts and leave the air inlet in the grill. Looks good and purposeful there. Putting smaller trumpet in fog light will give a less straight route and smaller inlet for the induction air. Less top end and mid range performance.
Looks mint how it is.
I have a brand new small pipercross in candy red if you fancy swapping? It was spare and never used.
Have a look at merlin motorsport, they do alsorts of trumpets, I bought a couple, fit exact in the fog light with a 76mm inside for your caf pipes. I will be fitting them the weekend.
Cant folk be arsed to write or something?, +1 +2 ....pffftttt
Yozza is it? brake ducting would be cool to use and mount the CAF behind that
+1
Especially when the grill has been hacked to bits to fit it.
Lol :rasp:
Big powered turbo cars need a big Caf. :)
Do we ? :eek:
my lower grill is trimmed not hacked :rasp: got a replacment now tho :) and new fog lights surrounds so will give a few things a try and see what happens
:lolup:
FOGLIGHT FTW!!!
Where did you get the Caf for your for your foglight ?
And how is it held in?
Looks not bad ?
Custom made. no trumpet, bit of fibre glass and some silver sprayed mesh to keep the squirrels out. Sounds amazing when it sucks.
I did have a CAF in my lower grill when I had my 172. when I was going to px it I needed to go back to standard so brought a lowergrill from ebay for £17 and sold my cut one for £15! Good result imo
