RS Tuner Initial Review
1200rpm? bit high isnt it? i've rempaed mine using the RS tuner and it sits at 1000rpm which seems perfect to me as it was a little below 800 before
Anyone used an RSTuner on an otherwise standard 182. I've just ordered one, but im having second thoughts as i've no other modifications on the car at all. The exhaust will eventially be replaced with a Milltek when the Renault one rusts through, but its probably good for another year or so yet. I take it the car will run OK on one of the 98 ron .cal files without having other modifications.
melchy, it might be a good idea to throw in a decent panel filter, but IMO even without that there should be a noticeable difference.
I havea cat back exhaust and thats it. The rs tuner does more than make good use of modifications. It improves the existing map, by raising the idle limit to 966rpm instead of 840...(roughly)
It improves the power band and spreads it out
It improves throttle response....i could go on :)
i got a question lol sorry about re brining this thread back up
1 can i use 95 ron fuel if i had to on this mapp
2 can i install it on my gfs 172 and a mate of mine aswell as mine 2?
Only if you purchase 2 additional licences from fast chip (£40 each iirc)
question about the license, if i buy the kit and remap my ecu, and a pal buys a license for himself.. and we do his.. can i then remap mine again? or will i need a new license >_<
excellent how do you know what map to download of rstuner? amni to belive theres 2 different types of ecu ? or do i plug it in and it tells me what i need
From what i understand from the site, It tells you on the RStuner what your Vehicle type is, and then you download the correct software + cal..
Ive not got one! :p
I ordered mine a week ago! Waiting for it to come through now (cannot see any order tracking information on the website apart from it saying it is "shipped")
ive just read the online manual slighty confused me on the which file to select for the car but ill read it again should be ok i think lol
homer-simpson what shipping method did you chose?
nice one Has...and what might be these details that are required for the second license?
btw, the previous car it was locked too wont work after a license change over.
Taken from FastChip site:
Need to program another Car ?
Provide us with your VCI hardware unlock code.
You can obtain this by connecting the VCI to your PC under: / about / unlock VCI / Copy to clipboard.
Send us the code by mail and we will unlock your VCI accordingly.
so if i install it first on my car then we install it to ryans with his unlock code i then need to pay for an unlock code for mine to re use it again ?
that's propper ghey! lol can see why they've doen it though I guess..
tbf at less than £150 its less than half the price of an off the shelf map elsewhere!
Yes.
Basicly once its used to flash a car, it becomes "locked".
Then you need to get it "unlocked".
So yes, double unlock charges for you doing it that way.
Best checking with Henk on this.
Could work out costly if you need to flash another file onto a car that you have done already.
Yes.
You do need to pay for a liscence each time but its one liscense per car so buy 2 liscences and program those 2 cars as many times as you want!
you had yours done schwepp? hows it running
Yep bought the kit last month. Doing a couple of the Bristol boys cars too and getting them to split the cost of the extra license to do my car!
Running much smoother now, especially on cold start. Torquier low down and its not all high end power now. Also the 7.5k rev limit is nice but doesnt really give you much benefit. I'm still yet to run a performance analyzer to see how effective it is though.
hopefully mine comes soon be nice to see if theres any differences and my gfs 172 has got the roughest idle aswell so wanna wack it on hers see if it sorts it out
Yes.
I didn't think this was true...?
You have to pay £40 everytime you want to remap a different car to the one RSTuner is currently locked too.
