36K service
Car  P2 172, 125d M Sport
I am currently on 32K and will have the pleasure :( of a 36k service soon. My car is a 2002 172. I know the aux belt will need doing on this service, but as my car is over 5 years should I get the cambelt done as well. Cheers
Yep cambelt needs doing aswell im afraid buddy
This is gonna be a big bill then, might have to sell a kidney. Is Yozza the best place to check out as I'm in Birmingham?
On a 1#2 the recommend times are 72K miles or 5 years old. Many would recommend 60K or 4 years on here though.
It’s a big job and a costly job
From an independent garage expect to pay around £450 -650 (172 cups a bit cheaper)
From a Renault dealership expect to pay £600- 1000.
Many chose to have the water pump replaced also as if the pump fails the whole belts job needs to be done again.
Rubber is funny stuff. Even if the belts look ok that doesn’t represent the state of the rubber. If a brand new elastic band is left in your garden over the summer buy the end of the season it will still look ok but if stretched it will break as the rubber would have become brittle due to the extremes of heat and moisture. The same principle can be applied to the rubber timing and Aux belts on the engine. All the rain and heat will have taken its toll on the rubber.
Nothing wrong with main dealers if your local one is decent but you will pay more for it. Definately get the belt done even though you've not covered the milage 5 years is the time interval for the cambelt.
as with all renoault parts i imagine a rubber band would be more reliable ;)
Should have done a bit more homework I think, found the best car I could (1 mature owner, low mileage), think I would have been better off finding one with a bit more mileage and the belts done. Never mind. Don't think I will even enquire at the local renault dealers. Had a 16v 10 years ago and both Birmingham & Solihull were rubbish, and expensive. Thanks for th help guys
Might have to tap you up in a month or 2. Do you have an idea of how much this would cost?
