Painted Interior bits
Whytes
  Clio 182
Just thought i show some pics of me interior as i just finished fitting it all back. I still need to do the gear knob insert, the bit at the bottom of the steering wheel (how does that come off ? pull harder?:eek: ) and the bit round the dials (got to take the dash off to get to that ?!?!:eek: oo might just leave that bit!!)
  Meg R26 + Mk4 GTTDI
i think u should do the button on the hand brake blue also! and u should give me your silver one:rasp:
Whytes
  Clio 182
yep ok i know one thing at a time :rasp: The cars due a clean this afternoon as long as it stays dry!
Whytes
  Clio 182
but then i wountnt have one to paint blue!cant you just paint yours silver?!
  "Navy" N17 TWO
:lolup: Paint your own ;)
Great job Whytes, what all did you use for the centre console?
I've got a few spares to paint when I get round to it myself
Whytes
  Clio 182
For the centre console: Keyed up the surface with 180 git wet and dry, then a coat of polyprop primer, or plastic primer. A couple of thick coats of polyester spray filler to hide the pattern in the plastic, rubbed down between coats,320- 400 grit wet and dry. Then a thin coat of normal white primer just gave it a tickle with some 400-800 wet and dry. Then the colour base coat, then within an hour a coat of 2k clear top coat. leave for about 30 mins another coat of clear. leave to harden for a few days then polish !
ForceIndia
  Gentlemans spec 200
Quality job, paintwork looks spotless, but I think it makes the interior look 'cheap'.
