lowering engine position
  vers le haut doigt milieu
y do u need to drop it by 1CM? ovbious CofG issues but just a CM?
  Ph1 172 + Combo van
could be a huge pain i think. alot of things would have to be changed /modified.
  F4R'd ITB'd '92 cup racer
why you wana drop it? bonnet clearence?
what are you a bloody mind reader!
next on my options list:
smack underside of bonnet with hammer
find a way to raise bonnet a bit (use a hammer?)
throw hammer at windscreen
set fire to hammer and car
go on a killing spree with flaming hammer :evil:
  clio 172, pulsar, evo
its amazing what can be done, there are companys that can roll a very small bulge in. i wasnt really meaning put an impreza scoop on it :)
try skimming the head... litrally. grind it down lol.
i think it could be costly whatever avenue you go down. what is the distance before the catch touches the clip?
oh the bonnet will clip into the catch
but its resting/pushing on the inlet plenum :( needs sorting before i take it out for a blast as the engine movement is going to damage something
only thing i can think (bit of a bodge though)
is to raise the front of the bonnet slightly (possibly using pieces of old hose pipe) where the bonnet quick release pins are
or make a bulge in the bonnet :S
somthing like that? :cool:
  M3 Touring
WOAH.... After sleeping on the idea I really think it should be Mad Max stylie, you flip a switch and the engine raises out the bonnet! *Que mad s/c noise*
haha that would look crazy on a valver, but maybe a lil silly :D
but i think its gonna be easyier modifiying the bonnet instead of dropping the engine down, chavy scoop ftw!
i presume that the bonnet is two skin? the our skin and inner skin? can you not just cut out some/most of the inner skin? Weight reduction AND solves your problem?
yeh beanie sent me a pic of a bonnet for reference, i have already chopped a bit of bracing out, but looks like i may need to cut some more out in order for it to fit correctly
time to break out the angle grinder.....my best friend :approve: :clown:
Gray- i love the way you think! :D :cool:
