Lacquer after polishing?
Car  Never above 25mpg
Just started doing my front bumpstrips and the lacquer reacted due to the cold of the garage (not the paint not drying this time :o )
So I was wondering whether after it's polished to bring the lacquer to a good finish whether you could re-lacquer over the top of the polish without it reacting or without it cocking up...?
Laurence
Reacted in what way? Clear coat tends to cloud when its cold, but usually dissapears when dry?
Well sort of patchy with a sort of "oily" effect when tilted in the light but completely dry. Disappeared after polishing but I didn't and don't wetsand the paint layer.
That happend to me shat myself thought i had to do it all over again !!
As for your problem try wet sanding it a lil with something like 3000 and give it another coat see if that lifts it if not time to re do
You wet sand in between the thin coats of the basecoat, but not the last coat before applying the Clearcoat. Yes? :)
coat ;)
FLOL ;)
The polishing seems to have either got rid or covered up the patchiness so just means I'll be polishing alot I guess ;)!!
Onto the next one tomorrow :p
id sand the it back down to the paint and put the laquer in a bowl of warm water to heat it up you should be ok then thats what i didi
what i do is after basecoat (colour) has dried or nealy dried give it a blow with a hairdryer to heat the part up and lacquer away, ;)
Primer, Blast it with heat gun another coat again with the gun, Colour on heat gun it repeat maybe 2/3 times the heat gun it again 2 coats of laquer heat gun it then leave it to dry over night then re fit or blow it with the gun for 15 mins at a distance and stick it back on.....
