172 rev limit
  RB 182 cup
right well my car never used to rev to the limit which i take is 7.2k, used to only go to 6.8k ish
changed the cts and all was fine again went to 7.2k but took it out for a long run yesterday and now its back down to 6.8k again now i will check the sensor tomorrow but its just strange how its not working again.
the car was deff up to temp lol but still cut in early??
any ideas before i get too involved checking things 2mo?
  e92 + E46 M3 + Cup
Have heard that 1st & 2nd gear give a higher rev limiter than the above... cant remeber where it came in now though... Re-map, 7,800rpm now days :cool:
cat171
Your peak torque figure will be a lot before the rev limiter tbh. So really you don't need to go round redlinnig it all the time.
  1998 BMW e46 323i
Tom are you sure it was up to temp? (I know you said you were). It reads oil temp and not water temp IIRRC. Can take a good while to get upto temp' depending on the type of drive.
  RB 182 cup
ive had a few cars fitted with oil temp gauges and i know for a fact it was deff up to temp. think im gunna plug it into the scanner at work and check what the ecu is reading from the temp gauge, at least then i will know where to start.
  PH1 172 Sport
As said 1st and 2nd have higher rev limits and TBH there's no need to rev to the limit as the drop in power towards the limit is considerable.
The car will take upto 15-20 minutes of driving before its warm enough to rev that high
Also the temp gauge in the car read the water temp but the engine only allows higher rev limits when the oil temp is high enough yet there is no indication of this in the car.
  Monaco RS Clio 172
imo the rev limit should be below 3k when the oil is not warm enough.
reving a car when cold is asking for trouble. staggering how manufactures haven't done this a long time ago tbh
I know this doesn't help you and is completely off topic. just my opinion.
sorry :)
(and I know you're not reving it when cold - so don't take it the wrong way)
  PH1 172 Sport
4k would be a bit more sensible imo especially if your going to be on the motorway before the car is properly warm
  53 Clio's & counting
the rev limit is the same through all gears guys, the car doesnt know which gear your in,so cant alter the rev limit. when warm it should limit at 7200 rpm, and this is measured by water temp which has to be at 85 degrees(iirc) to let the engine rev that high, when it is under this temp it will limit at 6800 rpm. so id hazard a guess that you moght have a fault with your coolant temp sensor, as the engine could be thinking its not up to temp
  PH1 172 Sport
I'm still 99.9% sure that its done on oil temp not water temp :)
Christopher
  Z4M
Water temp means bugger all from cold start really.
Oil takes at least four times longer to come up to full operating temperature. Longer than most people think. RS Clios have a soft limiter of 6800rpm until the engine's fully up to temperature.
1st and 2nd rev limit is 7250rpm and 3,4 and 5 its 7000rpm
it doesnt matey, most def 7200 rpm through all gears, iv tested ;)
Seriously though the ecu cant tell what gear your in,so it cant limit differently in certain gears
And im pretty sure its water temp related, though i wish it was oil temp
It can its given speedo unput form the abs computer/gearbox sensor depending on model.
And as far as im aware the clio dosnt do that matey, i know mine revs to 7200 rpm in the 1st 5 gears, anyone have any literature on this? there must be something from renault somewhere
Its the tech manuals.
Not that it matters rpm counters can be inaccurate etc.
sorry i should have said, yeah i realise rev counters are never accurate, but iv had mine tested (mates £35,000 worth of diag machine) and its within a few hundred rpm accurate
  1998 BMW e46 323i
We don't need literature from Renault. We have edde. End of.;)
  ClioSport 172 Cup
I have taken this from the renault literature.
Engine Temp <75C max rpm 6700rpm in all gears
Engine Temp >75C max rpm in 1st and 2nd gears 7200rpm
Engine Temp >75C max rpm in 3rd, 4th and 5th 7000rpm
Sam
