Help!! Front Wheel stuck on
  182FF
Wanted to swap my front and back wheels around to try get a bit more life out of my tyres...but my front wheel is well and truly stuck. Think it's rusted to the hub.
Anyone got any ideas how I can free it off?
mine were a little bit like that, i got the tool and stood and put all my weight on it to spin it then they just unscrewed normally lol
  Ph1 172 + Combo van
hit it hard with the palm of your hand at the top on the sidewall of the tyre. if not kick it, but be quick to grab it otherwise it might fall off and straight onto its face scratching the f**k out of it.
cat171
Sorted yeah ??
The wheels on vee's do this a lot, flippin right pain in the backside.
  53 Clio's & counting
VW's are terrible for it mate, a few wacks with a rubber mallet WILL get it off, though a prob with leaving wheel bolts on slightly is iv seen threads damaged that way, id take the bolts off, make sure its very well secured then a few hits on the tyre will get it off
When you put it back on give the raised part of the hub and part of the disc the wheel sits against a thin smear of copperslip. That will stop it sticking on again, reet pain in the arse having to kick the f**k out of a wheel to get it off.
  Ph1 172 + Combo van
clean it first and a quick wipe of sand paper before the copper grease will make it better
  alien green rs133
i have to over come this problem every day
undo all wheel nuts
then screw one back in a few threads with fingers
then hit/kick back of wheel
wheel will come loose but not fall off and scratch cause still a wheel nut in
hutchie
Yup 50 grit and/or wire brush to clean the fucker up.
cat171
^ did all that with the vee, a few months later they may aswell have been welded on, the sods !:dapprove:
