300BHP an ordered everything today came to just under 5000.how much this all going to cost then and what bhp you looking to get?
I dunno how much it would have cost to fit. ktec wanted bout 2000 for fitting.This is going to be crazy lol
Would it be better getting ITB's with Wild cams for about £4500 or a Turbo for £5000 (Not sure how much it's gonna cost to fit so didn't put it in)? This isn't a dig btw, I'm thinking about this for next year.... want usuable power though and I've been told anything over 220bhp in a front wheel drive car is where it starts to go downhill.
Ye got time off work done the same sort of thing before so its not totally new300BHP an ordered everything today came to just under 5000.
coooooooooooooooooollllll!!!!
i have been looking at the turbos for a while now! next year could be the time to do it!
so i take it you are fitting this yourself!
No got rid of that at the min they said try it without first.Still gone for the LSD too fella?
Need abit of help how do you get the drive shaft off on the drivers side???
Cheers mateNeed abit of help how do you get the drive shaft off on the drivers side???
knock the pin out the driveshaft it goes though it and pull the driveshaft off.
Has to be working and on the road by the 16th coz its going into rstuning then.Nice one ryan!!!! How long are you looking at to have it completely done on your side of the work that needs doing ?
Ye im from middlewich mate seen you about i thinkIf your local, i may pop up for a nosey around this
Good work!![]()
Ye thats fine mateI may pop round when your mid doing it then![]()
No was told it will be ok do you think i should?? been told its not really old enough an not done the milesLooking good mate, are you getting the bores re-honed before you fit the new pistons and rings?
Probably will be fine then, mine had done 76k so had it done just to be sure
Dont wanna do that could make the block to weak for the turboover bore it!
How much have you done it by iv got the standard size pistons coming now anyways.I have done it, not sure if there are any real pro's for it. We will see if it goes pop though...
Not got a choice now got standard rings. Been told by mate that fits them all time that mine wont need doing not old enough and not done the miles.As above, i wouldnt fit new pistons without honing the bores IMO.
