RS Tuner graphs in here please
  330Ci Sport Convertible
Ok just installed and ran a nice straight road [about 2 miles long] both ways.
Not remapped the car yet and its running a BMCCDA and a custom exhaust system. My results standard ecu prog are
If you have standard graphs or modded ecu graphs can you put them here so i can compare please.
  PH1 172 Sport
Heres my before and after graph. Green and Red is the after ecu remap graph.
Pretty similar to mine on the before. Going to install the group N and cal 98 tomorrow and see what i get
  Renaultsport Clio 197
here's mine... I was in the car with another person and half a tank of petrol and the weight might not be too acurate but hey...it's the only photo I have.
don't know what's the deal with the torque line lol, it's the same on every graph.
And btw, I did another run with just me in the car, 115kw ...
stock car, 9500 miles and 95Ron fuel on a hot day.
Not too good!
  PH1 172 Sport
One of the best mods ive done apart from matched inlets. It just improves the drivability of the car no end. Its so much smoother through the rev range and low down torque is much better.
Installed the group N map, took it for a few runs. Same road as yesterday but this time it is wet :(
Anyway thats about 145BHP at the wheels by my calculations,not bad in the wet :)
Had my lad in the car on that run so added 50KG. What is the standard weight?
Also it doesnt seem to rev over 7k,how long should it take to up the rev limit?
Not put the 98cal on,would that make a difference?
  PH1 172 Sport
I think they are 1090kg standard might be worth doing a search. You also need to do the test when the cars fully upto temp probably 15-20minutes of driving.
I found the 98ron.cal was better with back to back tests though you obviously have to use premium fuel to maximise the map.
Do you just upload the cal to the ecu ontop of the group N map?
What benefits does having the 98ron.cal bring?
  PH1 172 Sport
I just got higher torque figures lower down. Best to try both maps back to back see what your car prefer's
  RB 182 & Lotus Evora
Not too good!
1500kg is overkill
  PH1 172 Sport
As far as I am aware. Otherwise the next step is to get fastchip to make you a custom calibration for your car based on the mods you have.
  PH1 172 Sport
RSTuner calculates your power and torque from your rate of acceleration in 3rd gear and in its calculations it takes into account the weight you enter. Too high a weight and your figures will be too high and visa versa.
Therefore the weight you enter needs to be really accurate to get a good reading. You need to know the exact weight of the driver and any passengers. Petrol only weighs 0.737Kg/L so half a tank of a 197 is 27.5litres or about 20kg of fuel. So even with the weight estimates you have provided your off by 50kg.
