Fitting cup spolier.
6 screws out
remove cable for brake light
remove hose for jet
remove standard spoiler
and then reversed for the new one
very very easy
not sure about the washer pipe but on my dynamique i just pulled it out a bit more and it worked fine
i thought i remember reading on here that the connector for the brake light was different when changing from the standard 1*2 > cup spoiler?
Guessing the wires/ power source will be the same, so can you not cut connector off and attatch old one, then cover it in oodles of duct tape.
yeh. best thing to do would probally go to a scrappy and find one with a cup spoiler. cut the connector off and crimp it onto your car then you will be able to plug it straight in. the washer pipe should fit though as its just a rubber hose. Heres a pic of mine if its any help to you. i changed from the poverty spoiler to a dynamique one.
On the left is the washer jet hose and on the right is the connector for the brake light.
Alex G u have impressive skills for an 18 yr old m8
