Trigger Patterns
Car  1995 Clio 16v Turbo
Basically im after some info on the trigger patterns of the F4R engine as i am using one on my mk1 turbo conversion. Ive been informed that it runs a 60-1 pattern.
the thing is the standalone ecu im after recognises the standard 60-2 or 36-1 patterns and was wondering if anyone had overcome this problem and if so how, or are there other ecus out that there that recognise the 60-1 pattern.
many thanks
alex
cheers for the replys guys, as you say it is 60-2 so it will work with my ecu, i got my numbers muddled up somewhere.
Im using go-tech MFI pro as a mate of mine was running a similar setup on his rs turbo with good results and he can get trade discount for me.
ive managed to sort myself a flywheel and now im looking into clutches, any ideas where to get a good paddle clutch, ive had a look at the yozzasport one but there is no torque rating on it?
cheers
alex
all the "big tuners" use the helix grp A one, same as in the cup racers, its good for 300bhp and 250lbft IIRC there is also the Alcon clutch, but they're not as reliable
at yozza (when i was still envolved) we used the helix for 10K miles and only had 0.2mm wear on the friction plate
there is a grpA unit availbe from valeo and quater master
What's the difference between 60-1, 60-2 and 36-1?
Basic description will suffice, im logical enough :)
theres only 36-1 or 60-2
one gives more info as to the position of the crank.
so the ones running 60-2 will usually be running sequential/semi-sequential injection and wasted spark ignition.
the 36-1 will run a dizzy and batch fire injection
i guess i guessed wrong lol. Just with the batch fire injection sounded less economical and distributors i thoght were only used on the older stuff. newer cars have these stupid coil packs which are far too nervous.
