Boot build...
I'm in the middle of designing a boot build, and I'm not sure whether this is a stupid question..
Could I put an inverted sub facing down into the area where the spare wheel is? Like I said i don't know whether its a stupid idea or what so if anyones done it then let me know!
Heres mine. Ive changed cars now so if anybody wants it. £40?
You would need to build an enclosure for the sub to sit in, so the bass sounds right :)
As stated previously you would need to build a sub enclosure in the actual wheel well for best results....If your amp has a 'phase' switch it would need setting at 180 degrees, if not then simply reverse the subs polarity....
Yep it is here taking up room. Ill be glad to get rid of it as i can't really reuse it.:(
Ill sell anybody the sub aswell for a little bit more but for the £40 you will get the 10" sealed box which goes in the spare wheel well. insulation which goes in the well and keeps the box secure. the bottom layer which holds the amp and hides the wiring. and the top layer which is carpeted and has a plastic window so you can see the amp, with ventilation holes.
I am keeping the amp though.
alrite mate not sure if you know me from bristol but is that ben smiths old clio? and theres a good audio place call ice desighns in st annes worth a look
