Have replaced all above parts and more for oe and checked tracking too the car feels alot better but not perfect as it should compared to previous cars. Basically I still get the same symptoms. The rear subfame mounts cup holes wear/elongate, these are my next fix as I believe along with poor top mount design the excess movement creates excessive tramlining, castor and camber changes mainly under acceleration cornering and hard braking. I knew something wasent quite as tight or precise as turn in should be. IMO the handling seemes very floatey or sloppy at points due to this fact after rebuilding nearly all the moving parts and not eradicating this fault.
