Tracker ends
Car  120d M Sport
Need ur advice again everyone:approve:
Theres a bit of play in my steering from the centre, i.e. minor turn movements of the wheel either way dont have any effect at first
Am I right in thinking this is the tracker ends?
How much does this usually cost?
Thanks!!
disconnect them from the hubs to check for play in the pins to be sure before renewing them. you'll be able to pull them up and down in the cups if they're shot
or just jack the front wheel up and move it side to side!
if they are that badly worn then you will be able to feel it if not put the wheels on the ground and get someone to shake the steering and see then!
