clio 172 ?
Car  clio 172 cup
i am going to look at a clio 172 today its a y reg is there anything i sould look out for any thing that tends to go wrong ?
Itll will be a Phase 1 if its on a Y plate.
Make sure it has a full religious serivce history, also make sure that when you go and view it that the car is cold (a car can hide faults if its been warmed up prior to you going to see it) So ask specifically that you get to see it warm up.
Turn the wheel lock to lock, there should be no grinding, bumping or knocking from the top mounts. (this is normally caused by water gathering in the top mounts,i.e the top of the suspension turrets)
Make sure there are no lights illuminated on the dash, mis-firing is a common problem with the Renault Sports and is normally caused my a failed coil pack or injectors or even faulty spark plugs or HT Leads. Other than this just check for general wear and tear, if serived properly, it will last you long.
Also, if you can, try and get a paint depth reader, this could tell you of any crash damage the car has had across its lifetime (if i remember right they should read 145-148, consistently across the body work)
SOmetimes a HPi check will only tell you if it is catogorey registered.
Use this > www.mycarcheck.com ,the safest £3.95 you will spend mate
Not quite... here is my Y reg...
there is a good buyers guide in the members area. i found it useful when i was buying my clio.
thats a fair depth of microns ...... didnt realise they put so much primer / paint on them lol
In the 3 weeks i've owned mine, this is true ha I havent gave up the love yet though :rasp:
I've owned mine since August, only drive it weekends, and I'm sick of it! Drives fantastic, but it's the least reliable thing I've ever owned, wouldn't recommend!
I've had mine since september and love driving it.I spent quite a lot on it when I got it on sorting niggles with tyres, brakes etc , but its been ultra reliable so far. I'm just about to take the car over to northumberland via the A686 over Alston moors from Penrith.
If you are buying a 172, just make sure its a good one! Service history etc.
