My temp sensor is crazy!
Car  C63 AMG, F430 & 172
When the clio actually worked, when I would put my foot on the gas the temp gauge would sit at a constant max, then if you left off or go up a slight hill it would drop back down to normal level!
(car was not overheating btw)
Also has OMEX 600.
Could just be a temp sensor for the coolant?
Sounds like an earth fault, like the sensor is mashed into the TPS wiring, lol.
When temp sensor would be faulty the car would also be running funny, idling up + down etc.
^^ then yes i would def say so
(when thinking it through it seems logical to me + the temp sensors have a rep of going/failing)
Mine has just started going nuts too. On warm up it will go up to norm operating temp then wil start dancing around in between cold and normal. It did it last year but fixed itself. I was thinking an earth prob. Is there a common earth prob for the sensor? or do u rekon its the sensor itself?
