One question iPhone/iPT thread.
Re: iPhone Q&A DONT START ONE QUESTION IPHONE THREADS. **POST HERE**
You can't, they messed that up with the last software update.
I thought it used to be in miles. That explains it then.
Voice guidance/turn by turn sat nav available for Jailbroken iPhone's via Cydia, xGPS.
I'm hoping someone can help me!!
Everytime I receive a call it comes up Unknown. Even tried it from my house and it done the same yet we are not ex directory or don't withhold number.
Does anyone know why sometimes i have to slide to answer an incoming call and sometimes i have the option of 2 buttons; 'decline' or 'answer'?
Depends if your phone is locked, or not.
Aye, if it's locked and 'black screen' you'll get the slide (to unlock it as well), if you're usnig it or the menu screen is showing then it'll just be the two buttons.
So much little awesomeness, it even spaces the number you're dialing to take into account whether it's an 0870 or a normal 01XXX number...
is the person or number calling set-up in your contacts list? if not that's where the problem lies.
Yup.
If its ringing but you dont want to answer. Just press the power button on the top and it stops the ringing. Effectively putting it on silent ;)
If the number is not blocked at source then it should still show on the iPhone screen, it does not need to be in the contacts list.
mines says it's blocked if that's the case though - never had an unknown....?
Anyone using the latest revsion of clippy? it really is amazing.
My iPhone is close to perfect!!
Clippy? Never heard of it :D I assume it's a jailbreak app.
after updating my firmware i lost my jailbreak stuff do i have to re do it?
Just add "All Sources" and search for clippy unless you are using installer...then you are quite simply a n00b.
Mine has decided to power down and will not power back up again. Is this a known problem, any fixes as obviously you can't do the remove battery reset that resolves most phones when they crash!!
DFU, restore done.
Hold both buttons until the Apple appears.
If that wont work, Hold the home button as you plug it into iTunes and it will force a restore. Hopefully you'll have a back up on iTunes..
Is it just that the battery has got very low? Leave it on charge for a bit.
Just found the home + power button for 10 seconds method. Nope plenty of battery just decided to shut down for no reason like a kernel panic. Second time it's done it in the last 3 days! I'm getting deja vu from the K850i hassle I used to suffer :(
Some numbers are in my contact list and some aren't eg work numbers but they are never withheld!!
give o2 or apple a call - sounds like a software issue then
iPhone Software 3.0 - Out 17/6 & iPhone 3GS - Out 19/6
http://www.engadget.com/2009/03/12/iphone-os-3-0-is-coming-march-17th/
Exciting!!
WWDC Live link
http://www.engadget.com/2009/06/08/phil-schiller-keynote-live-from-wwdc-2009/
Iphone 3GS – S for Speed
8gb 3g - $99
16gb - $199
32gb - $299
- 2.1x faster to launch Messages
- 2.4x to load SimCity
- 3.6x faster to load an Excel attachment
- 2.9x faster to load a large website.
- Supports OpenGL|ES 2.0 -- great for games.
- Supports 7.2Mbps HSPDA.
- 3mp auto-focus camera with Automatic exposure and white balance. Better low-light sensitivity and auto macro
- Camera supports 30fps VGA video capture, with full video editing facilities and uploadable to youtube direct from phone
- Voice control e.g. Call ted, play la roux, play more songs like this etc.
- Digital compass which will point in your direction, will show you what direction your walking on a google map.
- Support for Nike+
- Improved battery life. Now up to 9 hours of internet surfing, 10 hours of video, 30 hours of audio, 12 hours of 2g talk-time, 5 hours of 3g talk-time.
Released June 19th in the UK.
Re: iPhone 3.0 Discussion
Good thread :cool:
Will be keeping tabs on this one.
what is in this update? free i presume?
yeah, jail break it and install clippy via cydia
Bah. Jailbreaking my Gen 2 Touch FTL. Cant do it at the moment, IIRC.
Cheers anyway.
