cirlcip welding.
CLIO-Si
Car  1.6Si + 182
just had the boy round to look at my car and the where the circlips needing welded into and gonna get it done in the next few days,
i have got mattblacks post saved in my bookmarks and also a picture saved on my computer of the circlip welded into place,
wondering how precise the welds have to be to allow the driveshaft in and to sit right as we have one shot at it and dont want t f*ck my gearbox,
also will the diff still move in and out when welded or will the clip+washer hold diff in
other inputs/views would be gratefull as said we only got one shot at this
thanks.
weld the circlip only to the housing
leave the washer behind and the driveshaft free :p
leave the driveshaft free??:S
it seems the cv gaitor and the 3 knuckles will miss the washer/circlip as the gaitor sits an inch in from the entrance and the knuckles should go in past the clip/washer,or will it?
my clip popped out and driveshaft became loose so had to get new shaft/s and new clip,weld it in and a gallon o oil
surely if its welded it would only come loose again with harsh drivshaft movements
the picture thats posted above only has 3 or 4 spots on it but the pic i have saved has like 6 welds about an inch and not just spots so surely the better its welded the stronger its going to be
It does, it just seems to break through the weld.
break threw on good welds or just spots?or it does with harsh movements?
could just weld right round it maybe?
as i mentioned
people have pics of spot welds when others have like inch welds and depending on how much abuse your driveshaft is getting,
and yea people have more power than others,
matteh what do you mean by leave the washer behind and driveshaft free??
thanks,
the circlip holds a washer in place, but the washer should be free to move, so only weld the circlip, not the washer
what movement does the washer need? yea ill put both washer+clip in then weld clip,
does the washer or clip get in the way of the shaft going in atall?
is there a slot for the little bit on the circlips noticed that on the pics i have both dont have the bit in where i would think it would go,
where the long-nose pliars would tention the clip it seems to be where there is a litle gap which i wouldave thought the little sticky out bit would go into and the bits for tightning would be at the other side of the circle,
also a few questions in this post which im still unsure of could someone read over and clarify a few of my points please,
thanks,
Apparently, if you want a strong weld don't use spot welds. As a general rule of thumb, a 0.250" (quarter inch) weld which is an inch in length, will take 1 Ton of force to shear it. This is what Gaz has been told by qualified welders.
what a 1/4 inch in penetration? you'll struggle to penetrate 6mm in this instance!!!
the old 1 inch of weld = 1 ton of force does ring true, but thats on a min of 1.6mm thick using the hounsfeild (IIRC) test method (ie stretch test) same "strength" if you will on same material thickness can be achieved on all forms of welding, MIG, TIG, gas and ARC (well close enough if you're good!)
so the 1/4inch weld x 1inch long is incorrect if you're on about penetration thickness, 1/4inch penetration is major heavy industry! 1/4 inch pen x 1inch long should theoretically support upto 4tons, but i have consumed stella, so i might be off slightly! ;)
also have to account for dissimilar metals, those welds can looks strong, but fracture very easily if the steels are very different (which they will be as the circlip is a spring for a start)
bet those dont get used often though, most pics i've seen are a blob of MIG or straight TIG with what looks like virtually no filler rod used
certain materials when TIG'ing won't take that well (if you know what to look for) something like 308 or 311 (IIRC, its been a while!) are excellent on dissimilar stainless for example
CDS to 4130 again requires a specific weld rod, or you could just "blob it up with MIG"
hey guys any updates on this thread. Mine circlip failed on me today left my car stranded at work. Till i get it towed on Monday to the mechanie. So how many other guys have there circlip welded in and how long has it lasted for?
Just want to get an understanding on how long I can expect before it going again?
can anyone answer my question about the little sticky out bit of the circlp+washer in the pics ive found they dont seem to be in the little gap where i wouldave thought that it would sit in,
also "leaving the washer free" does it need much space or just hard back as it will go them circlip hard to it,
does the circlip+washer get in the way of anything once its in or the welds get in the way of anything,
does the clip+washer just basically keep where the shaft goes into the gearbox(diff?)from spinning freely as when its moved out towards the hub it will spin round but when pushed into the box that 5-10mm its solid and where i want it to be?
thanks,
i dont think welding it in will work personally the clip is one a spring and 2 too thin so putting enough heat to melt it (ie welding) will cause the metal around the weld to turn brittle and it will crack round the weld next time it trys to jump out
no expert but thats what i'd have thought
Im going to try and get mine welded and go from there. .
I think by note having it welded it in there may cause it to happen again unexpectedly.
I've had the passenger side driveshaft jump out of the gearbox on 2 occassions(S-reg Clio 1.2 8v),the mechanic says theres not much gripping the driveshaft in to the box where the circlip goes,so does anyone know the answer to stopping this happening again,thanks.
