does i have any bad effects removing it at all?
just make sure you block the vac hose that connects to the head, just cut it short of the head an seal the end,
Does the ph1 even have one?
is this the hose that joins to the induction bend?
No, that'll be your idle valve.
nope, this is the crankcase breather..
It's the one that connects below-in front of the TB, front side .. (see if i can find a pic) But anyway ! just pull the tube from the valve and stick a screw in the end..(tad oversize so its a tight fit) job done
DOH ! you have a phase one , never mind
