Removing acoustic valve.......
just make sure you block the vac hose that connects to the head, just cut it short of the head an seal the end,
Its a pice of piss.
Passenger wheel off, wheel arch liner out, Acoustic valve out.
Sorted.
No, that'll be your idle valve.
nope, this is the crankcase breather..
It's the one that connects below-in front of the TB, front side .. (see if i can find a pic) But anyway ! just pull the tube from the valve and stick a screw in the end..(tad oversize so its a tight fit) job done
