172 ph1
172's rear suspension fully dependent? If so, why the need for a rear anti roll bar?
Hoping to hear from those of you with a better technical understanding of the rear of the Clio 1*2...
The first time I saw my car jacked up, I was quite shocked to see that the rear seemed to be fully dependent. I also did not notice a rear anti roll bar (perhaps I did not look carefully enough).
I take as reference a picture from Yozza's blog:
It seemed like the 2 rear wheels were attached to a H shaped frame (think of a horizontally stretched out H) at the H's feet, and the 2 tops of the H frame were attached to the chassis. From what I could see, both wheels must move up and down simultaneously by the same amount, making them fully depedent.
If this is the case, then I don't see why there would be the need for a rear anti roll bar kit such as the one from Whiteline http://www.balancemotorsport.co.uk/products.asp?recnumber=58832, or the need for rear strut braces.
I'm guessing that the rear is not fully dependent but somehow semi independent? If that's the case can someone briefly explain how that's achieved?
