You could go with white to go with the wheels or black to go with bodywork and contrast wheels.
How To: Did mine recently
You will need to take the wheel off to get best results.
Get your hands on a wire brush that can be fitted to a hand drill. This is used to remove rust/corrosion/ dirt etc...
Once all dirt has been been rid of wipe them down to remove the little particles of rust, metal etc...
Now, use masking tape and tape around the bits you dont want paint on. e.g. brake disc.
Now the paint:
You must use high temp paint for obvious reasons.
I got the paint from halfords for £5.99 and was enough to do about 8 if you wanted to.
Just give the caliper around 3 coats of the stuff ( its quite thick ).
I gave mine about 1 hour drying time in between each coat, (was sunny day).
All in all should be around 4 hours total time for one at a time or 5 hours if you do both at same time.
Hope this helps.
Evoss
I would recomend getting bigger wheels aswell with lower profile tyers for a better look.
Silver or Black, It takes like 10min, but you dont want to drive it for the day tbh.
Do it in the morning leave it till the evening (Y)
Oh and swap your 15's for my 16's, lol.
Will bear it in mind. But no matter how much cleaning they require, i love mine![]()
Im dying for a set of turini's in 15, so if you do ever fancy a change...
shut up....
those wheels are fine.
id paint them silver if it was mine...
black/white will keep the theme upYh gold would look good on anything but white wheels lol. Im torn between red, green or black/white.
IM thinking that aswell. Just dont know how to go around putting it on the calipersblack/white will keep the theme up![]()
^ Take the wheels off first :lolup:
I laughed so much at that one!
