stripping rear problem?
maynard
  ph2 172 track car
anyone else have any problems stripping the rear of their clio?!
them damn two bolts holding the isofix bar are damn tight. almost feels like ive rounded the one off!
what did you do to get them out?
Dicky Belly
  Whichever has fuel
I snapped a Halfords 'pro' ratchet doing mine.
Used a wheel brace and a scaffold bar in the end. c**t of a thing to remove.
Rojer
I didnt have any problems was a bit tight just wiggled it haha use a bit of wd40
maynard
  ph2 172 track car
ive tried the spanners, ratchetts and using my foot can only get it out so far! just feels like its rounding off now :(
dad's coming over in the morning with some grips - hopefully that will get them out.
maynard
  ph2 172 track car
yeah me too! sat on one side using my foot to help push the spanner - proper weakling ffs.
is there enough room to thump the ratchet with a soft faced mallet? providing it's a reasonably large bolt head and your ratchet isn't too cheap, that'll often start problem bolts
  Astra 1.9Cdti SRi
nope no problem, just rounded off 1 bolt, and the other came out a treat :)
if your dads coming over in the morning, soak it in wd40, itl be easier then.
maynard
  ph2 172 track car
erm.. yeah there should be to hit one with it - not sure if it will work though being though i think ive rounded the one off!
good idea ill go soak them now.
  clio 172 cup
Seriously, no need for brutality, just turn it back a turn for every 2 turns. Slow and steady wins the race.;)
aye, violence might not be the best idea if it's already started rounding. not sure you'll get much more leverage with grips tbh, although shouldn't slip off so easily
maynard
  ph2 172 track car
right..soaked in wd40 now hopefully that will make some difference.
yeah i was going slow and steady but was actually taking forever. most of the backs out now just these two bolts and rest will come out.
hoping the grips will work a bit better other im knackered.
  alien green rs133
i used mole grips
was temped to drill mine haha
but came eventually, i put it back in with copper grease
is the other end of the bolt exposed under the car? clean the threads up and WD that if they are
(sorry, misread and thought you were trying to start the bolt, hence hammer suggestion)
maynard
  ph2 172 track car
how would i use a torx bit to get that bolt out?
henry - no probs :)
maynard
  ph2 172 track car
im not sure will have a look, if it has ill try that too i the morning.
maynard
  ph2 172 track car
i guess that bolt wont have a torx hole bit in the top of it then.
  330Ci (Fail)Sport
Centre of the bolt is torx 30 or 40 I think. I think I used the wheel brace from the spare wheel to loosen it and then unscrewed it with my fingers, was easy and quick.
Major issues with the main bolt for the rear seats. I rounded off the torx hole and its stuck halfway out atm.
maynard
  ph2 172 track car
right got the back out eventually (involved sawing that bolt out) it just wouldn't budge!
anyways got new problems now..new thread to follow.
