197---Anyone removed first CAT?
Car  Clio RS 197
has anybody removed the pre-cat aswel as the main cat?
I have removed that main one but was thinking about removing the pre-cat too.
ffffffffffllllllllllllllllllllaaaaaaaaaaaaaaaaattttttttttttt ssspppppppppppooooooooooottttt!!!
meh same difference i reckon. Leave well alone, judging buy all the problems the secondary one gives
I tried with different settings on the stock exhaust system, and found out that removing the secondary cat and leaving the first cat with stock exhaust is the best setting.
I tried putting on a straight through pipe with the 1st cat and decat the 2nd cat, but suffered badly on low end torque.
I will be trying with a Ktec racing catback exhaust and see how it goes.
Anyone with the 1st cat removed with a dyno map?
We have to find out the reason right?
Desm
Desm
got an pics of ya manifold work?
yea..ill take a pic when my car gets hoisted the next time.. but i believe the custom pipe will be useful on track as the torque after 5000 rpm improves though the low end suffer.
I believe B16 OJB meant ""Y-Pipe" for OEM manifold" they didnt mention if its decat or a highflow cat :P
*knock knock*
Anyone else decat the first and 2nd cat and it works fine?
*knock knock*
i hope they do bring it out!
I have removed both cats but i had a new branch and free flow made up for me and wow what a difference
it sounds awesome and has longer legs in the higher gears
It would sound epic with no cats and im sure you could spit a flame or two. However i wouldnt bother as people say, even removing the main cat has it troubles.
