dipstick snapped
Car  1.5 Clio Dynamique
he had no right to :lolup:
but seriously just went to check my oil and found the other end of the dipstick is missing. i can only assume the worse has happened and its gone down into the sump.
will it be ok (draining oil soon so might be able to retrieve it that way)
it shouldnt get into the engine as the filter will block it.............wont it???
That thing is relatively sharp. Especially if its snapped! As above, probably better to find it first :)
Edit: Also you beat me to the joke :P
just had a look and i cant find it in the lil tube holder thing.
a mate was helping me servie it early so ill have a word with him and hopefully it snapped and he got it out..............hopefully
no
ive looked cant get anything down to try and get it up. tried pliers, knitting needles the lot
would it be possible to take the oil filter out and try and poke it up
think it's solid behind the filter - just oil galleries
can you poke some wire down the tube to see if there's an obstruction? then measure the length of wire, match it against the rest of the stick and see if that tells you anything?
sounds like a sump off job anyway
ed. thinking about it, it's going to have dropped into the sump anyway - sump off, defo
ed. this post was cobblers (confusing my cars) - therefore removed. prev. post still stands. hope it's not too bad anyway
an inch of the stick goes into the tube but looking at it i cant tell weather i can see the dipstick of a reflection from the torch
looks like its a sump off job
pull the dipstick tube out carefully and you see the dipstick as your pulling it out of the block
can also use a smaller tube in between the broken one and a bit of silicon if you wanna cheap easy simple fix. - if its the tube
lol, reminds me of when mine broke. had to super glue the handle loop and contact adv spray the dipstick in the spout. push it on leave it a few seconds and pray to feck that it pulls the stick out.
hopefully he has fixed this now.
It's a piece of piss to remove the sump, I don't know why everyones going to such extreme lengths not to?
