Engine coming out... What to replace?
  M3 Touring
The dephaser SP? pulley has started to die. Which makes a lovely noise now..
Clug Clug Clug Clug Clug Clug Clug Clug Clug Clug Clug Clug Clug Clug Clug Clug Clug Clug :dapprove: The noise is resonating down the whole camshaft
So I have decided to take the engine out.. So I can give everything a good clean and sort out a few other little jobs in the bay.
So apart from changing the pulley and fitting a new cam belt kit are there any other suggestions on what else could / should / would be done while the engine is out?
The car has just done 88,000 miles..
the clutch (orignal) still feels fine but surely covering 88K must be close to wearing out now? :S
Dicky Belly
  Whichever has fuel
As much as your budget will allow imo.
Mounts, clutch, belts....... Will feel awesome knowing its as fresh as a daisy.
  Mondeo TDCI 130
GRAY! Your making a big job out of a dephaser pulley surely?! Just replace it and rock on!
  M3 Touring
My original plan was:
New pulley
New cam belt kit
New water pump
New clutch
K-tec uprated engine mounts
New ARB / wishbone bushes ?
New track rod ends
Maybe a set of orange SFS coolant hoses (depending how much the above costs!!!)
Then be a tart and paint, clean as much as possible ;)
  M3 Touring
meeeh.. I do keep thinking that, but at the same time should I just do everything at once?
Knowing my luck I will do the pulley then the clutch will go LOL
  Bus w**ker
I'm with the above mate, too much work just because of the dephaser pulley needing replacing.
I'm off all this week so gimme a shout if you need a hand (as in I stand about and point at things).
M
mini-valver
Fag! Leave it in and do the pulley, then replace the clutch when it slips!
