Hi im a new clio owner and am looking to get to work straight away on updating the soundsystem. Can anyone tell me how to wire up 6x9s to the parcel shelf?
help would be much appreciated!
Regards
Gallaz
Wiring them up isn't really an issue until you have sorted how you intend to install them....
BUT; First things first....
Will you be fitting any type of sub in the boot???
If yes, then give the 6x9s a miss, if no, then I would recommend you seriously consider either making or purchasing a 'stealth shelf' to guard against both theft & shelf sag....
I would also recommend you seriously consider using an amp to drive the fronts & the 6x9s as this will improve overall flexibility & quality....
Obviously ignore the above if a sub is in your future plans....
