Clio switches off on Idle!!?!?! help!!!
Car  Renault Clio Mark 2
Hello everyone,
Need HELP!! I just got into my Clio (Mk2 1.6Si), and switched the car on. It came on for a second and switched off. I thought that was my mistake, but on switching it on again it kept switching off, infact it will only stay on if i have my foot on the accelerator and keep the revs to at least say 1500rpm.
When I take my foot off it jus falls to 0 rpm straight away!!
It was fine yesterday, literally started happening now. What is this problem? What do I do??
Any help is much appreciated!
Thanks
my 1.6 used to cut out sometimes when i would change gear and then refuse to start again
had a major fix at renault where they changed alot of things but didn't know what fixed it:S
Could be the idle control valve then, probably best to get it on diagnostics, save replacing working items then.
If its the old 8v engine I bet 99% it will be the idle control valve.
