I've just got myself a panasonic 46' widescreen plasma, how can I adjust windows to display everything in widescreen as everything looks a little bit stretched.
2000/xp etc
right click on desktop > properties > settings and change the resolution.
win 7
right click on desktop > screen resolution and change
Depending on how you have connected the pc to the tv and what resolution it can handle it will decide what resolution it will allow.
Also keep setting it higher until it stop showing on screen then go down one resolution dont worry if you dont click accept it will go back to the orginal so the resolution wont c**k up!
also dont forget to change it back before you go back to your monitor as if the TV is hd and it has a higher resolution you'll be fooked and have to change back to the tv change the res and back again
