exhaust wrap bandage? Anyone tried before?
I just got a pack of Billion exhaust wrap bandage, it is a brand from Japan.
Sorry, I really dun know if exhaust wrap bandage is the correct word.
Anyone fitted before on their exhaust manifold?? Are they good.
I got becos its cost is lower than I expect :-D
I had it on my 106 GTI and although i dident notice any difference in performance (dident expect to) the under bonnet temps came well down, which is good. i only did it because i was replacing the manifold, dont think id take the manifold off especially to do it
I don't need it to make my Clio performs better, but really wish it can cool down my engine temp. HK is damx hot!
wrap is good stuff, it makes s**t loads of dif to temp in the engine bay.
on my vtr:
Not a fan of exhaust wrap, seems to me like the perfect wick for a candle, especially when covered in the typical Clio oil leak?
Heres my 4-2-1 manifold wrapped two years ago. It cools down engine bay a lot and in theory it should help engine performance by acceleration exhaust gases. After two years the wrap itself started to break unfortunately.
I have it on my 172 manifold and downpipe simply for the fact to keep heat away from the brake lines at the back of the engine bay, as I dont have a heatshield there.
Its been spot on, never had an issue with high engine bay temperatures on trackdays and the brakes have always been spot on...
I painted the manifold and downpipe with VHT paint, then wrapped it, then sealed the wrap with specific sealant...
Sorry, question.
Seems I have to remove the exhaust manifold right??
Plus, do I have to lower the engine first in order to get the exhaust manifold out??
thx!
keep the heat in the exhaust gases, so they exit the exhaust faster... i think... :)
Correct the use of Heat wrap is more suited to turbo cars as spools the turbo quicker = More Power! but as said will help a lot with under bonnet temps!:evil: But I dont think you will feel any performance gain in your Clio but it all helps!;)
