Full Tank mileage
Car  182 ff
hey people
filled up yesterday as per norm only to get 395 miles on my digi (bp)
normally fill up and its 365 max ( v-max)
does anyone know what the full tank can hold in laymans terms pls
mark
hey people
How much?? i get 280 to a tank, 310 if i drive like a nun and change gear @ 2500/3000 rev's
its a 50 ltr tank, most ive put in mine was around 48 ltrs.
thing is i think the trip computer might be f**king up as last week i had 140 miles on the clock hammered it for about ten miles, abs light and esp light came on so i stopped to reset it ( turning the car on and off )
only to see i had lost 60 miles ????
if im full, i read 360odd miles in tank. i fill up at about 50miles left in the tank (at the lowest).
must be about 50 liters. (nearly 11 gallons?)
Depends how you drive. its all worked out on averages.
Sometimes i can poodle home 3 miles from the local shell, get 40mpg (its a short run along the motorway) and ive got 450miles range (11 gallons full). Sometimes ive been out, so the car is warm, and it gets some heavy right foot action and i get 25mpg on the journey home. range then is about 250.
320 usually from full till red light
I always fill mine up and reset the millage so always know how many miles are left in the tank.
Most i've ever put in was 44ltrs
i only get about 280ish out of mine, but most of my driving is stop start sitting in traffic! dam traffic!
I normally fill mine up at about 1/8th left (one notch above 'empty').......normally get 240 miles per tank from full. Normally says 30-50ish miles left.
Yes I 'enjoy' my car every day ;) didnt buy it to drive like a granny! Although long runs I'll get 40-42mpg down to Dartford area where my best mate lives. Normal combined according to the car is about 28/29mpg. My drive to work is country B roads all the way :D
always get 310 to mine.
f**k me 395 miles!!! you must idle every where.
lol na this was when i filled it up it said that gave it a bit 100+ for about 5 miles and it just said 384 lol ,normally get 330 ish
thats why i think my read out might be fucked :rolleyes:
50 litres isn't it?
I run it till the light comes on and then fill up, but I have never managed to pack more than 40 lts in. Spoke to the local stealers to confirm the tank capacity and he said it is 50lt, so I should get about 100 miles on the fuel light! Have'nt risked it yet....
I get about 360 miles from 40 lt so im happy with that.
thats why i think my read out might be f**ked :rolleyes:
The trip is based on the MPG's you are getting at the time. If you reset the trip often the read out will always vary quite significantly, where as if you leave if it for a long time it will eventually flatten out.
Best way to work it out is to take a note of the miles you have done since the last fill up, use the amount of fuel used to fill the tank and turn into gallons (remember UK not US), do some maths and get the true MPG.
managed 282 miles on this last tank, just put 46 ltrs in, trip computer showing 386 miles left but that will soon drop when i drive to work.
another thing i no loads of u wont agree with is i only use normal 95 (Shell) if i use the 98 grade i get less mpg
yep
ran it for 8 months using only 97/98 RON (always Shell, never used any other)
changed to 95 RON got more mpg (only 20/30 miles or so to a tank) and the car ran better so always used 95 RON ever since.
Normally anything between 250-270 for normal town driving from a tank.
But when we went to Bristol I got 365 from that tank.
With the fuel light on I can get around 40 litres into the car, and from that I can get about 400 miles of town driving and back road blasting.
(Don't do motorways round here)
