M
		mini-valver
CBA ordering the wrong kit so what do you reckon?
			I read that all the heads were machined separately to match the block height.
It can throw the comp/ratio out if you mix and match.
Yeah. Have 2 bottom ends, 1 ph1 and 1 ph2. Ph2 has done less miles and come from a belt snap/ Ph1 has had the sump cracked when crashed into a wall.
Plan is, ph1 head on ph2 BE for a quick runner, then build a proper bottom end form the potentially dead ph1, rebuild the head from the ph2 with headwork and bolt it all together, replacing the quick build.
Definately ph2??
Nope, different kit and it buggers the timing if you have the wrong.
i have got ph1 172 with a ph1 bottom end and ph2 head, works perfect and if anything it pulls better than before,
Same combo as me. :approve:
Hard to tell if it made a difference.
