Need Windows
Status
Not open for further replies.
Tom
Car  i3
Whats the cheapest legit way of getting a copy?
XP or 7 Dont care which edition.
the upgrade can be used to install clean
install with out the code the do a re-install with a code
Why do you need more details?
Its simple. Imagine i am a normal person.
I have a copy of XP depends how legit you want it. lool
Isn't it illegal to use a windows disc which comes with another PC/Laptop?
I have a copy of XP too. But it's currently installed... I'm guessing it wouldn't work if I sent you the disc?
What the f**k is wrong with you?
LEGIT!! i said legit!!!
Surely there is no middle ground here. it either is or it isnt.
Tom, if you want it I'll send you our XP. But I'll need it back after you install... So it depends whether that's ok or if you want an edition of your own.
OEM copy form ebuyer... along with another piece of hardware (sata cable or something cheap to keep it legit) ;)
There are differences between retail and OEM licenses tho.
Needster, if this is disc is from a brand named company e.g. hp dell etc it won't work on anything but the same brand machine, because they verify against the bios of the machine.
(If it is a big brand name but different HP disc / dell machine, you can alter it slighty so that it will work fine..., if its a self built jobbie it wont work without some major fiddling)
Its not a self built machine its an apple.
Dont worry, its cheaper for me to buy a s**t 2nd hand laptop than it is to do this.
Status
