What to clean earth points with?
ForceIndia
  Gentlemans spec 200
Having a few electrical gremlins, so going to give the earth points a clean. What's the best thing to use?
Gaz_
  Extreme mode
Wire brush/course sandpaper if its say an earth strap to the chassis. Remove the lug first, clean up both contact areas, and refit
Vaseline or aerosol white grease should prevent them from corroding for a while once clean. can buy dielectric grease, but it's expensive and you'll never use it again
  ValverInBits
yeahp bit o grease to prevent corrosion.
Daniel
  Whichever has fuel
So can a 12 bore.
And right now it seems like the only way out!!
